Hi,
So as to break the ice, I'll start off with the following question.
Is it possible to have an equation in a schedule that runs something like this "IF (<Relevant property has a value>, <Another IF-string>, <0>)"?
I'm trying to utilize the "issued"-checkbox in sheet issues/revision list. I have a sheet list that marks every unissued sheets with an "X", so as to easily show wich are the newly revised sheets. At the same time I have another sheet list that only shows unissued sheets. That way I can easily publish every sheet that is unissued by using the publish function.
The schedules that I have are working fine, except for the fact that sheets that have yet to have a revision applied appears with "X"-es in my schedules. The obvious fix is to exclude all sheets without a revision from all my sheet list, but at certain times it is nice to include those in the sheet list as well.
Cheers
Håkon Nilssen
